01ssvert
12-22-2004, 06:01 PM
Hey everyone,
I need help with this one. I installed a new spec 3 clutch along with a new steel sfi approved flywheel & new slave. After install I took it for a ride & took off easy to help the clutch break in. But turned it up to 6 grand & noticed at the high rpm it felt down on power & vibrations i never rememberd. It was all stock before I made the change & now if I bring the idle to 1000 rpm the car vibrates in a way that does not seem right, as soon as it goes to 1100 its smooth & seems smooth till high rpm free revs. Also, I recieved a code for knock sensor, 2 codes, one said bank 2. I then hooked hp tuner to it & did a scan & saw at 5800 KR went to 4 which before I never got KR at all.
Im thinking the flywheel might be out of balance or the clutch?? All the parts were new, although I did cryogenic the flywheel to help its heat properties. That should not take it out of balance. I even put the dowels from the old flywheel to the new one. So I know the clutch lined up correctly.
Any suggestions are much appreciated please.
Thanks
Scott
Thanks
Scott
