Pontiac GTO 2004-2006 - Water Leaking Inside
View Full Version : Water Leaking Inside
captain107
12-26-2004, 03:02 PM
Anyone had a water leak inside passenger compartment. The carpet in the back seat on the right side is soaked and it is wet around the rear windsheild top. There is also some water in the front corner outboard side. I think it is coming in through the weather strip seam on the roof. Does anyone know how this plastic seam works. I'm going to the dealer tommorow.
CSiJason
12-26-2004, 03:12 PM
That is truely odd... Perhaps the rear window seal is bad.
Nick368
12-26-2004, 03:28 PM
I had a leak on the driver a pillar while going through a car wash. I brought it to the dealer and they had a window company check the pressure and the seals. They told me they needed to order a new seal and I'm supposed to have it taken care of this week, under warranty of course. My car only has 2,000 miles on it.
Take it to the dealer they should set you straight.
Nick368
12-26-2004, 03:29 PM
Take it to the dealer, this is a problem they've heard about.
SDB
12-26-2004, 10:23 PM
I have the same leak on the driver side rear, went throgh carwash and rear mat was soaked. Dealership looked at it, said it needs a water deflector part, should be here soon.
SDB
captain107
12-29-2004, 09:16 PM
Thanks for the info. I have 5700 miles on mine. The dealer called me last night and said they were still looking at it. I am going to relay all this info tommorrow. Again, Thanks!
Supernoma
09-17-2005, 09:20 PM
This is a nagging issue for the GTOs. Mine is in the shop getting new carpet (water damage completely soaked the passanger side carpet, beyond repair)
Check the drain holes under the carpet around the doorsills, that seems to be a trouble spot.
I will caution you, if you do get new carpet under warranty its takes at least a month for them to get it..... Im going on 3 weeks now. :(
