I have a 2002 Slp camaro ss.With the centermount. Well i took my stock exhaust off and replaced it with the loundmouth cat back. Then i put a 3inch slp ypipe on and it feels so much stronger. What should i run now?
Stock i ran a 13.3@105 so what should i do with the exhaust and ypipe
the CME and the loudmouth flow basically the same as meentss02 said. Sell the CME, a lot of people would want that.
I'd say, you will run just a tad better than you did before under the same conditions, although the car has a lot more than a 13.5 in it stock
