Prothane Polyurethane Motor Mounts
My ORY is hitting under the car and I do not want to give up any more ground clearance by adjusting it (I can still go over speed bumps). I was wondering if anyone has used the poly motor mounts and had luck with them. Do you think they will help? I have about 1.5" between the Y pipe and the car, it only hits in 1st, 2nd if it grabs some traction. Also any write ups on installing them. I have not payed attention to them while I have been under the car. Thanks
