Stand alone? For street
Old 12-29-2004, 09:08 PM
White98Z's Avatar
Default Stand alone? For street
Well i have had enough problems with me stock computer system and was wondering how good a fast, accel, or one of those big stuff 3 are for everyday driving and what not.
Old 12-29-2004, 09:59 PM
GPel's Avatar
The BIG STUFF 3 is a very good stand alone & can be used for every day street use. We have a couple of guys running around town w/ it. You need to have some one/shop tune it for you or get a good base tune & play w/ it from there. Do not try & start from scratch w/ any stand alone. Just my 2 cents
Old 12-30-2004, 09:02 AM
Lethal Injection's Avatar
F.a.s.t is also a good system. I hear BS3 has more options but I hear getting in touch with a person to find out about it is hard. The guys on Turbomustang are not getting any info. Maybe that will be corrected.
F.A.S.T. is pretty easy to tune once you understand what each graph does to your engine. You will need someone to tell you that because the manual does not do a good job of it. It is easy after that.
The unit controls
A/F ratio
timing
cold crank
idle
nitrous activation
nitrous fuel
added fuel for nitrous
logging
IAC controls
auxillary fuel enrichment
My advice would be to pick a seller that has a reputation (good one) selling and running that system. Make sure he understands you need help with a base tune and a good understanding of the system.
Old 12-31-2004, 10:35 AM
White98Z's Avatar
O i would not be tuneing it tell after i learn. Would have some one eles doing it. I just kind of want to get out of this 98 computer and wireing harness plus new motor should be going in soon.
Old 12-31-2004, 11:27 AM
7 Second Club
NicD's Avatar
Well it all depends. I personally wouldn't spend the money on an aftermarket ECU for my car unless I really needed it. Like if I was running a lot of boost, had money burning a hole in my pocket, etc. What kind of problems are you having with the stock computer?
Old 12-31-2004, 11:53 AM
Does your avatar reflect stock ecu tuning? J/K could not resist it!
Old 01-01-2005, 07:59 PM
7 Second Club
NicD's Avatar
That is what happens when somebody bounces off the limiter on bottle repeatedly. No, it isn't mine.
