Pacesetter ground clearance
Old 01-01-2005, 11:50 PM
lazyj02's Avatar
Default Pacesetter ground clearance
I was wondering how much ground clearance anybody running the Pacesetters had. Im staying at stock height and I was wondering if Im going to get caught up in driveways or on speed bumps
Old 01-01-2005, 11:55 PM
fasthwks's Avatar
Pacestters ory and sportline springs and have no problems, don't worry at stock height.
Old 01-02-2005, 12:07 AM
Z28Venom's Avatar
There's absolutely no issues with Pacesetters and ground clearance. My K&N oil filter hung lower than the Pacesetters did.
Old 01-02-2005, 12:19 AM
lazyj02's Avatar
Thanks that makes the decission simple
Old 01-02-2005, 12:33 AM
ddelallata's Avatar
Clamp positioning is KEY though. Make sure that the nuts/bolts are pointing to the side instead of downward.
Old 01-02-2005, 01:44 AM
ss rally red's Avatar
Although its just asthetical I dumped the U clamps and got some band clamps from NAPA, looks WAY better
Old 01-02-2005, 01:59 AM
Z-286speed's Avatar
You will be fine on a stock ride.
Old 01-02-2005, 06:34 PM
-Q-
-Q-'s Avatar
If you go with the TSP catted Y, make sure you adjust those fittings to get the whole pipe assembly as high as possible. The Y hangs a little low and I've already bumped it on some steep angles.
Old 01-02-2005, 10:17 PM
99SeanWS6's Avatar
You should have no problems with stock springs. When I had my intrax springs it was a whole different story
Old 01-02-2005, 10:32 PM
Ferocity02's Avatar
Pacesetter = Great ground clearence
Old 01-02-2005, 10:34 PM
Black02SS's Avatar
I have them on my car and the ground clearance is awsome.
Old 01-03-2005, 08:40 AM
FRCBobby's Avatar
This is good to hear, I have debated back and forth between Mac and Pacesetter. Definitely Pacesetters for me now.
Old 01-03-2005, 05:49 PM
Mat
Mat's Avatar
I'm going to be ordering the TSP catted Y.. I saw a thread on here a while back with a stock height car and a pop can in the photograph for scale. Looked pretty good to me! It's probably all in the adjustment just as someone else mentioned!
