Just purchased a ported throttle body. Is there a adjustment on the sensor to make?
Old 01-03-2005, 01:23 AM
1 BLOWN V8's Avatar
Default Just purchased a ported throttle body. Is there a adjustment on the sensor to make?
Hey all.
If I remember right isn't there a adjustment I need to make on the throttle body sensor to get the most of it? If so can someone tell me the exact #'s I will need. Thanks
Old 01-03-2005, 09:08 AM
Bo White's Avatar
Get ya Fluke meter out and adjust the TPS until it reads 4.6 @ WOT.
Old 01-03-2005, 04:21 PM
Another_User's Avatar
You may need to adjust your set screw to get your IAC counts right. I made some directions on how to do this on here awhile back.
Old 01-03-2005, 07:25 PM
1 BLOWN V8's Avatar
Which thread was it?
Old 01-03-2005, 07:55 PM
https://ls1tech.com/forums/showthrea...=stop+drilling
Old 01-03-2005, 08:21 PM
Cstick's Avatar
Rather than adjusting for WOT TPS voltage. Idle I believe should be around .5V +or- .05V.
Old 01-03-2005, 08:40 PM
Yeah, the voltage doesn't really matter as long as you don't exceed the maximum at WOT. And that can only be done by grinding the top throttle stop. Your car will re-learn WOT as 100%. Mine always does...some people have had weird things happen where it doesn't, but I have no idea why that is.
Old 01-04-2005, 06:02 PM
Cstick's Avatar
I would worry more about voltage than percentage. The computer does not care about percents it wants to see what amount of the 5V reference comes back to it. It can be adjusted by turning the TPS sensor. If the holes are not slotted you can slot one of them to get the right V. 0.5V at closed throttle.
Quick Reply: Just purchased a ported throttle body. Is there a adjustment on the sensor to make?
