Valve Cover Spacers and Stock Length MSD Wire Question
Will my stock length MSD Plug Wires work with a 1/2" valve cover spacer? If they are tight that is fine but will it work? Thanks.
I have just solved my problem thank god. I got the 1" spacer from a member on Eastern Fbody and Taylor Truck Wires also. Woohoo. Now all I need to do is find the proper rocker system.
