Fueling & Injection - Anything else I need for Racetronix intank system?
mike#9
01-03-2005, 09:12 AM
I just bought the Racetronix 255 intank system. I picked up the wiring harness also. Is there anything else that I will need...or is recommend for easy install or better function. I have a 01' SS...will my Fuel Pressure Regulator be ok?
Also, I picked up some Delphi/Lucas 42# injectors and fuel rails from Speed Inc. How is this for a fuel setup for a H/C car and a 100-150 shot of nitrous (wet)?
TAQuickness
01-03-2005, 11:46 AM
That should be it. I just received the same kit and will start the installation tonight. I've read about a few guys here that cut an access hole in the rear deck, but I won't be doing that. I'll let you know how it goes.
mike#9
01-03-2005, 11:07 PM
Thanks bro!
The injectors may be overkill...but I can afford them...so why not....you can never have enough insurance!!
sickss228
01-05-2005, 09:06 PM
I just installed my racetronix pump and wiring harness simple as hell to install, you should have no problems very well designed kit, if you run into any problems shoot me a pm, good luck
mike#9
01-06-2005, 07:30 AM
Thanks brotha!
98,Ram,Air
01-12-2005, 10:42 PM
Put mine in yesterday. Sweet set up! I ended up running the power wire through the interior by the rest of the wiring under the drivers side carpet. I didn't like the look of all those tie wraps down the fuel lines. I screwed the relay next to the black box by the wiring harness infront of the tank. Looks so factory, like it alot.
SlickVert
01-24-2005, 07:57 AM
Where did you buy your Racetronix kit at?
LawmanSS
01-24-2005, 10:48 AM
You can get them through Racetronix directly...not a sponsor, PM sent.
AnthonyR
01-24-2005, 11:12 AM
Thunder sells them, they are a sponsor
csmonte
01-24-2005, 10:36 PM
Ordered mine through Moore Performance....You should really check them out :nod:
I do like Thunder Racing, good guys, better than a few other sponsors. But check Moore out first.
Good luck. I should be putting mine in this weekend.
Billiumss
01-26-2005, 03:06 PM
Where did you have the wire go through the firewall at on the drivers side?
Bill
csmonte
01-26-2005, 06:51 PM
yeah, I got mine in today, and no directions ??? :confused: . I know the LT1 kit is different but someone needs to explain. I'm going to go try to mess w/ it in a sec and see if I can figure it out.
Mine got here in 3 days. Wasn't even ready yet :)
oh well. I'm taking pics and such to help others in the future but I gotta figure it out for myself first :confused:
Racetronix
01-31-2005, 11:13 PM
e-mail support@racetronix.com for instructions
