AFR 225 small chambers (62cc)
Old 01-03-2005, 09:23 AM
SlickVert's Avatar
Default AFR 225 small chambers (62cc)
AFR 225 small chambers (62cc) where are they?
Tony, how about an update please.
Old 01-03-2005, 09:39 AM
RX-Ben's Avatar
I was told end of January, so you may want to try this again in a month.
Ben
Old 01-03-2005, 03:56 PM
6 Second Club Moderator
LASTLS1's Avatar
I'm also waitning for the small chambers!
Old 01-03-2005, 03:59 PM
InsomZ's Avatar
w/ a z06.. what will that put the compression at? w/ the 62cc chambers?
Old 01-03-2005, 06:09 PM
SlickVert's Avatar
Insomniak,
62cc heads, should put the compression around 11.1
Mill them to 58cc with a 2cc valve relief (fly cut pistons for larger cam) should put it at 11.3
Looking forward to these heads!
Old 01-03-2005, 11:43 PM
InsomZ's Avatar
thanks.. thats what i'm wanting.. 11.1:1 so i can still run pump gas..
hope these know heads can crack the 500rwhp mark w/ a g5x3 cam.
actually i'd be happy w/ 450rwhp lol i've seen as high as 485rwhp out of the 205cc heads
Old 01-04-2005, 08:54 AM
SlickVert's Avatar
With the right set-up they should push over 500rwhp
Old 01-04-2005, 09:00 AM
DrkPhx's Avatar
I thought the 62cc heads will just be milled and not a different casting.
Old 01-04-2005, 09:11 AM
RX-Ben's Avatar
The tech @ AFR I talked to said it was a different setup altogether and NOT a milled version.
