Fast94
01-03-2005, 08:07 PM
2 or more heads > than 1. I can't close my hood on my 94 Camaro. It's hitting right about where the MAF is..and it's a good 2+ inches from closing. I already messed with hacking the lower airbox off..but it still hits. We will be grinding the metal radiator support and bending it down but that may give only about an 1" more clearance. I have an aftermarket hood, but the cowl doesn't start right at the tip :bang:. I haven't put it on yet,,so hopefully it will be high up enough and fit over the problem..If that doesn't remedy the problem..then what can I try?
Has anyone done a swap into 93-96 F-body? Any problems with hood clearance? The nose sits a lot lower than the 97+. I don't want to modify the intake like the LT1 style either.
I probably already thought of every possible way,,but hopefully I'm missing something obvious. This part may have to turn into a major hack job :(
