Cam Help!
Cam Help!
I'm looking to buy RUQUIK's T/A. I think his cam might be more than what I'm looking for. Here are the specs:
Magic Stick 240/244, .608"/.612" LSA
I know this sounds odd, but can somebody describe to me how this is going to sound. I asked him and he said it was choppy. Is this going to have a rough idle, like it's going to die at idle, or do they just sound like that upon starting the car. Any help would be appreciated.
He also has TS&P Stage III Heads. If this cam is too agressive, could someone recomend one a little bit more tame, but still with a little bit of ***** behind it.
!LS1 11 Second Club
I say you bought yourself one mean daily driveable setup.
It will lope hard at idle.
If it's tuned properly, it should not die at idle and it should not surge too much at all.
I wouldn't take that cam out unless you've tuned it and it still gives you problems. That's one sweet cam.
2 questions: auto or manual tranny? what kinda gear is he running out back?
!LS1 11 Second Club
Originally Posted by NassyVette
Thats a big cam. The lower the LSA the "lopier" it gets. Duration helps with the lope too. Anything over 226 is usually considered big for a stock motor... A 112 LSA may be too much for you..you could do 113 or 114. What are you looking to get out of the cam?
230 duration cams are more and more common every day and very streetable with today's tuning. 240 durations are on the large end, but still streetable with proper tuning. 226 is rather small nowadays.
I agree with your "What are you looking to get out of the cam?" statement however.
The thread starter should know he has a very aggressive (for a stock ci motor) setup built into his purchase. I would stick with the setup, as most people waste about 2 years building up to that setup in a progression of small to mid to larger cam purchases and head swaps. If it's too aggressive, then the cam could be scaled down a bit, (but the stage III heads would be pissed IMO ).
The TSP MS3 (the cam currently in the car) is streetable and one of the better cams available on the market as it incorporates incredible top end power with a streetable low end and good mid range.
yeah, id say that h/c combo is matched up pretty well. the only thing i may add is u may wanna look into some bigger gears for the back. it will make that car more fun to drive. u see, with that big of a cam, your power isnt going to wake up til higher in the rpm band, so youre gonna have a lil lag time til the power kicks in. thats where the gears come in. u know how u seem to have good pull all over the rpm band with a stock car?? well, thats cuz the power:gears is matched up really well. with this setup u have, having bigger gears in the rear end (3.73 or 4.10) will allow u to spin the motor up faster, getting u into the power band quicker. i hope that makes sense. im in the same situation...i need some bigger gears in my rear cuz of my new h/c setup, but im thinking i might wait til i can afford a 12 bolt and do it all at once. anyway, good luck man, thats a sick car u got there
