EGR Removal
EGR Removal
What's the advantages and all in the removal of this? Is it really worth it. I don't think it will release any more hp will it? I've got it tuned out already. I just can't figure out what it will help out with. I've heard it hurts you gas mileage a little but what does that matter.
I'm doing it as soon as I get my block off plates for the EGR and AIR that I ordered today. Now that I'll have some room on the front of the passenger side head I'm going to order an AMW catch can as well.
I think I am going to do it now. Thanks Guys! I made my own plates for the air pump. So I'll just use that same stuff for the EGR too. What is an AMW catch can?
That's what she said...
I just pulled mine off. How is the best way to seal up the hole in the intake? Major vacuum leak there!
Originally Posted by TheBlurLS1
go to the autoparts store and buy a 1-3/8" (thats 1 and 3/8 of an inch) adjustable freeze plug. it looks like 2 washers with a piece of rubber between them and a nut on the top. turn the nut, it squeezes the washers together, expands the rubber, and seals the hole. i've got one on mine and it works great. Orileys had a 1-1/4" thru 1-3/8" one, as well as a 1-3/8" thru 1-1/2" inch. i got the first one and it worked great. only like 3 bux
Yeah, one of the guys in the local f body club that I'm in had a 98. he told me about the freeze plug. Don't know why I didn't think of that. It worked perfect though. Thanks for the help!
only reason I removed the EGR was because the LS6 intake I put it didn't have the provisions. I would do it if you ever plan on getting a LS6 intake or if you are just bored one day. Threw codes for me though.
