squealing belt
Old 01-06-2005, 11:26 PM
blu98ta's Avatar
Default squealing belt
First off my belt like sto squeal ALOT. Anyone know why it is doing that? I have been told to put Di-electric grease on it. I have tried doing that, but the squeal comes back after a week or so. I just replaced the belt tensioner and that didn't help either. The belt is also fairly new too. Any ideas?
Old 01-06-2005, 11:56 PM
Z28Venom's Avatar
First thing...
You don't put **** on that belt. AT ALL. even that belt dressing stuff is crap.
If your belt is squealing, make sure that it isn't all cracked to hell. After that, get a good view and make sure that all of your pulleys are lining up properly.
Once you've replaced the belt. I would start looking at the tensioner and idler pulleys.
Old 01-07-2005, 12:04 AM
blu98ta's Avatar
Ya like i said I just replaced the tensioner, and the belt is not cracked, it is basically brand new. The squealing is kinda on and off. I noticed today when it is cold outside it takes it like 10 min of the car being on before it starts to squeal. Any thoughts?
Old 01-07-2005, 12:30 AM
Krab's Avatar
I say you need a new belt, or atleast buy one, try it on and see if the squeeking stops. If it doesn't, return it and try something else. Putting that stuff on your belt, or WD-40 might stop it for a while, but the chirping will return.
Old 01-07-2005, 12:44 AM
Z-286speed's Avatar
I have had the same problem. I put WD-40 on it and will still come back. So, i tried motor oil, and has not done it after i did that.
Old 01-07-2005, 01:07 AM
Z28Venom's Avatar
You guys are killing me...
You put motor oil on your belt??
Old 01-07-2005, 01:12 AM
blu98ta's Avatar
Isn't the squealing coming from the fact that the belt is slipping? Won't motor oil only make it slip more? Will I hurt anything if I put oil on the belt?
Old 01-07-2005, 01:22 AM
8-Pack's Avatar
Dude did it just start this, cause mine has done it since pretty much new, 23,000. I kinda just accept it, I mean **** is just going to make noise, as long as the car is running fine just accept it. Some things can be fixed but sometimes squeaks and such are just part of life w/ these cars
Old 01-07-2005, 01:56 AM
blu98ta's Avatar
It used to only do it after the belt had been wet, and now it just does it when ever it wants too.
Old 01-07-2005, 02:48 AM
CarrotcarZ's Avatar
That is EXACTLY what is happening to my car......it used to only do it when it was wet......now it does it rain/shine!!!
Old 01-07-2005, 10:57 AM
blu98ta's Avatar
what did you do to fix it?
Old 01-07-2005, 11:25 AM
mean00SS's Avatar
see if your pulleys are out of line thats prolly what it is
Old 01-07-2005, 11:27 AM
FatZ28's Avatar
My car does the same thing man, for some reason it eats belts. the guy I bought my car from has dealt with numerous ls1 cars and say they have a tendacy of eating belts.
Old 01-07-2005, 11:31 AM
blu98ta's Avatar
but the belt is not torn up at all. The belt is just fine.
Old 01-07-2005, 11:36 AM
98 Camaro Z's Avatar
My car is the same way, it makes noise when its cold and goes away after about 10 minutes. I also put a new tentioner on it and still the same. I replaced the belt with a new one and it went away for and 2 or 3 thousand miles and now its back. It doesn't eat the belts up or anything though. I do agree, do not put anything on the belts. Even hitting water holes in the rain can throw a belt off, think about the silicone and all that other stuff thats in the dressings. And motor oil??? I've seen it all now. I can't believe that didn't throw it off. Your luck is better than mine.
Old 01-07-2005, 04:19 PM
Cstick's Avatar
Maybe I missed it above, but have you for sure narrowed it down to the main belt and ruled out the small A/C belt. If not I would take one off and see which one is squeaking. I see you replaced the tensioner how does the idler feel.
Old 01-07-2005, 06:58 PM
cheetle's Avatar
My car has a similar problem. It squeaks when its warm or humid out. But never when it's cold. My belts all seem to be in good shape. My a/c refrigerant is low....don't know if that has anything to do with it. Where is the idler pulley? I'm new to LS1's and don't my way around this engine much. How would one's pulleys be out of line if they've never touched them?
Old 02-13-2005, 11:15 PM
2000KCTA's Avatar
My car also is doing that. The problem is addressed in a TSB. (00-06-01-008 MAR 2000 Accessory Drive Belt - Squeak/Chirp Noise)...but that is as far as I have found. I would really like to actually read the TSB to see what the fix is.
Old 02-14-2005, 06:52 AM
blu98ta's Avatar
Tsb??
Old 02-14-2005, 09:38 AM
Harley-Davidson88's Avatar
That's exactly what I was gonna say. I have seen a lot of people change out the serpentine belt, tensioners,...etc and it was just the A/C belt. I'm willing to bet that is your problem.
Quick Reply: squealing belt
