At what point are different length pushrods necessary?
At what point are different length pushrods necessary? I am using a .045 gasket (~.010 shorter than stock), and am curious at what point shorter pushrods become necessary? With heads milled .020? .030? .040? .050? The cam is ~.030 smaller than factory cam, so doesn't that make up for the first .030 (head milling and gasket difference together)?
Thanks, Shawn
Thanks, Shawn
Originally Posted by Viper
In short when geometry is altered from optimal and when you cannot atain the proper lifter proload. The reason there is seldom problems with ls1 combos is that the stock lifters have quite a wide variation in acceptable preload. However, geometry may alter to the point of different pushrods may be necessary. Theoretically you should start the rocker tip at the intake side of the valve stem at zero lift, the rocker tip should be in the middle during mid lift, and the rocker tip should be just to the exhaust side of the valve stem during peak lift.
