ORY problem
ORY problem
My buddie and I just got done installing LT's and ORY. Everything fits fine but under hard acceleration the ORY hits the bottom of the car under the driver. I have not heard about this prob. before and is irritating the hell out of me . It is about a quarter in. from the bottom of the car.
What about a radiator hose and hose clamps to absorb the impact?
Other than that, Pacesetter LT's and the Hooker cat-back combo are great, it is more quiet than my LM alone
That's what I did.... I sandwiched in a piece of radiator hose between the ORY and floorboard. Don't worry about the hose melting. Mine hasn't and it's been on since this past summer.
Originally Posted by ZR2877
When I had my ORY it did that. You are right about it being irritating. I got rid of mine and got True Duals.
I'm not that worried about it, it will be fixed soon. Now that I know what to do.
Take the Y back off and beat the underbody(where it hits) with a mal. It wont hurt a thing. If the exhaust is touching the body it will transmit false knock, and pull timing. Ive been there.
You could try the Mufflex y-pipe hanger...it's designed for this very purpose:
http://www.thunderracing.com/catalog...&vid=3&pcid=54
(3rd item on the page)
I'm going to try the radiator hose and clamps today and see what happens but the hanger looks like a good option also. I'll let you know what happens.
Where does this mount on the y-pipe?
https://ls1tech.com/forums/showthrea...mufflex+hanger
I am installing my TSP offroad pipe tonight and it looks like I will be having the same problem. I guess I will do the radiator hose and clamps.
That Mufflex bracket looks pretty nice also, I might look into that if the hose doesn't work.
I am putting poly motor mounts on to fix my banging. I do not like the idea of a rubber hose. The engine wants to move and putting a piece of rubber between my y-pipe and the car is not really fixing the actual problem, its the motor mounts.
Think I may go ahead and order my mufflex bracket. The heater hose just isn't cutting it for me. Made it better but it still bangs a lot. Ill post about how the bracket turns out, although I may try and do motor mounts too. If I can find the time . . .
I put the hose and clamps on last weekend and it work's great, no more banging and run's very smooth. If that did not work I would have ordered the hanger but it did work.
