Coil Pack relocation.....
Its to cold out to take some pics but getting the coils mounted together is the easy part with all thread, nuts, and some hollow tubes for spacers. On the ends of the coil assembly I had pieces of angle iron. For the passenger side I welded two bolts to the front angle iron facing up. All I did was find the best location, then drill 2 holes in the cowl for the bolts to come up through. You can not hardly see my passenger side coils and how they are mounted. The driver side was different, I had to fab a special bracket I can not explain but you will see how much tighter space gets when you try to fit the coils back in that side. I welded the same studs, but had to mount using a strap coming off of the angle iron at a 90 angle then bolt to the lip of the cowl. Looks good once all the plastic gets put back on, better than the kits. Tips -I did not pull either of the winshield wipers, paint the brackets (oops) before final install. Making the plug wires sucked. I had a heck of a time getting the boots on the wire with lube. Goodluck, rewarding project.
Originally Posted by Marc '99T/A
Parts list! Install guide! Installed pics! Writeup link;.........PLEASE!!!
I'll let you know when they're ready to go!
