Automotive News, Media & Press Television | Magazines | Industry News
Official 2006 Corvette Z06 Images and Specs
Old 01-10-2005, 04:23 PM
Ws6Extreme's Avatar
Default Official 2006 Corvette Z06 Images and Specs
Here is what was released today...
Previous Z06 models, from the original 1963 model to the 2001-04 editions, incorporated suspension and/or engine upgrades that complemented existing Corvette systems. Not surprisingly, the specs for the ’06 read like the blueprint of a champion. They include:
* LS7 7.0-liter/427-cubic-inch Gen IV V-8 with lightweight reciprocating components
* 500 horsepower (373 kw) at6200 rpm
* 475 lb.-ft. of torque (657 Nm) at 4800 rpm
* 7000 rpm redline
* Titanium connecting rods and intake valves
* Dry-sump engine lubrication system
* Engine hand-built at GM’s new Performance Build Center
* Aluminum body structure with one-piece hydroformed perimeter rails frame and magnesium front cradle
* Fixed roof design optimizes body rigidity and aerodynamics
* Carbon-fiber composite front fenders and front wheelhouses
* Unique front fascia incorporating a larger grille, cold-air scoop and lower air splitter
* Wide-body rear fenders and a unique rear spoiler incorporated with the CHMSL
* Huge 14-inch (355-mm) cross-drilled front disc brakes with six-piston calipers and 13.4-inch (340-mm) cross-drilled rear rotors with four-piston calipers
* 18 x 9.5-inch front wheels with 275/35ZR18 tires and 19 x 12-inch rear wheels with 325/30ZR19 tires
* 3-inch-diameter exhaust with bi-mode mufflers and larger polished stainless steel tips
* Engine, transmission and differential oil coolers; and steering cooler
* Rear-mounted battery to improve weight distribution
* Unique interior features including revised gauge cluster and lightweight two-tone seats with more aggressive bolsters
* Curb weight of 3130 pounds / 1419.7 kg (estimated)
* 3 inches (76.2 mm) wider than other Corvette models
* Vehicle developed simultaneously with C6-R racecar.
MORE.....http://www.lastofthebreed.com/News/G...06Corvette.htm
Sorry if it is a repost..
Old 01-10-2005, 06:07 PM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
I plan on seeing this car in person this Saturday in Detroit! I can't wait!
Quick Reply: Official 2006 Corvette Z06 Images and Specs
