Please help with busted water pump... I think.
I believe my water pump just went out. I can only see a leak where it mates to the block on the bottom side of the pump. Is this the sign of a bad pump? How hard are they to replace? Any special tools besides a torque wrench needed? How much do they cost? Sorry for all the questions. I'm a little pressed for time and in the middle of my workout - so I would usually use the search button. Plus I need to get to work tomorrow. Thanks in advance.
Thanks for the reply. I replace it this morning and I'm pretty sure it fixed it. I didn't see anything wrong with the old pump but it's not leaking anymore. The hoses were fine and the only thing I saw was coolant dripping onto the sway bar and back onto kmember and oil pan. The hardest part was getting the old gasket off. Replace it with 99+ gaskets.
