Comp R lifters??
Old 01-11-2005, 07:03 PM
MOTRUBL's Avatar
Default Comp R lifters??
What is the main difference between the Comp R lifters and stockers?? I heard that they're the same thing just not as suseptable(sp?) to collapsing. Any info you may have is appreciated.
Old 01-11-2005, 07:08 PM
LSUxBlake's Avatar
They're a pain in the ***, they dont work right if set to the specs that Comp tells you to set them at, they're noisy. I'm going back to stock.
Old 01-11-2005, 07:18 PM
MOTRUBL's Avatar
Damn... that good huh?? What's the problem with them other than noise?? Are they hard to set??
Old 01-11-2005, 07:20 PM
LSUxBlake's Avatar
You should really do a search. Some people on the board like them, some people hate them. They're not hard to set, its just finding something that works. I've tried all the recommended settings and I still have valve float from hell at 5200 rpm. I followed the recommendation of a few members as well as some sponsors and I'm taking them out this saturday when I swap heads. There are people running stock lifters with 500rwhp on here, I figure my motor will do just fine on them.
Old 01-11-2005, 07:24 PM
MOTRUBL's Avatar
I see what your saying. I tried searching and all I got was anything with "Comp" listed. Let me tell ya I got a ton of those. Thanks.
Old 01-11-2005, 08:00 PM
RX-Ben's Avatar
Comp Rs aren't the only option for a high performance lifter- you can go with Morels ($450) if you want to upgrade from the stockers. Pricey, but they've been tested to all extremes and are extremely well made.
Ben
Old 01-11-2005, 08:15 PM
8 SEC SLOPPY SHOT!!!
tuff's Avatar
I have comp r no problem here i set the preload at .15.They look like stockers hell for all i know they probley are and that why i don't have a problem.
Old 01-11-2005, 08:41 PM
SmaknaSS's Avatar
Ain't that the truth, It's hard to set the preload on the comp R's when your by your self and have no help turning the crank pully and trying to find TDC, I said F#$K it! and ripped them out and put in Comp 850-16's OEM type replacments. A sponcer on this boad recomended the comp R's to me. My bad for not knowing any better. But all's good now.
Old 01-11-2005, 08:51 PM
jason5's Avatar
i installed them on my rebuild and set them to to the specs comp told me, they are noisy as anything cant even here my cam over them, i hate them i will be switching them this summer
Old 01-11-2005, 09:15 PM
DAPSUPRSLO's Avatar
What kind of preload are you guys running that have had bad luck with them?
Old 01-12-2005, 08:23 AM
SAM98WS6's Avatar
.008-.010" preload...work like a champ here.
Old 01-12-2005, 08:25 AM
LS1TECH Sponsor
Steve Burger's Avatar
I guess I am the one that is not having problems with them I set them and have not done anything else.
Old 01-12-2005, 08:35 AM
DAPSUPRSLO's Avatar
I think if setup properly these are suppose to be a great lifter, especially for high rpm super agressive lobe guys.
Old 01-12-2005, 04:17 PM
Louis's Avatar
They are, they are fine as long as you set them properly and know the metallurgy of aluminum
Old 01-12-2005, 06:45 PM
MOTRUBL's Avatar
What is Comps suggested preload?? Is .008-.010 the closest preload I should go with??
Old 01-12-2005, 08:00 PM
DAPSUPRSLO's Avatar
I was told to go between 1/8" to 1/4", more toward 1/4", on my preload. I did not measure it with an indicator but was told by Jason that this would be the key with the T&D Rockers. I guess I'll see this weekend.
Old 01-12-2005, 09:16 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I run a set and am making 738rwhp... but some shops say that you need to run more spring pressure to make them work.
I have been running a set of Crane doubles and am switching over to a set of Comp 977's to address what might be some valve float for me at 6500+. Prior to this new cam I was pulling to 7000 with no float at all and my valvetrain was not overly. I do think that running a cam with fast lobes mikght be noisy with Comp R's but I'm not sure. When I had a 422ci iron my comp s1 was noisier than my older lunati 242/242/114 cam.
Old 01-12-2005, 09:47 PM
BLK01WS6's Avatar
I remember the only problem with the Comp R's was that you couldn't get the pre-load set properly with Yella Terra Rockers. You have to run adjustable rockers in order to get the pre-load right. But once the pre-load is set right you won't have any issues.
Old 01-13-2005, 12:32 AM
Louis's Avatar
You dont need adjustable rockers.
Old 01-13-2005, 04:38 AM
MelloYellow's Avatar
Hate them.
