Band Clamps/exhaust leak
Ok so as i was installing the Y pipe on my Pacesetters i clamped down the band clamp and then all of a sudden the damn Pipe shifted on me. I had to take it off, reposition everything and i clamped it back down. Would something like this cause the big exhaust leak im experiancing now? Would a new band Clamp with some Hi temp cooper RTV fix this? thanks
Kleeborp the Moderator™
RTV won't affect your O2's as long as it is downstream from them. Not to mention they have sensor safe RTV. I'd get the two pipes tach welded together and then use the band clamp with RTV. No leaks.
