Coolant leaking
TT-TECH Veteran
Well did you just install something? If so did you put the block off plug back in the head ( Probably not it it is hard to miss that one.). If not then it could be a leaking head gasket or it could be one of the blockoff plates that used to be for the coolant crossover tubes. Could be a heater hose. Just a few to check. Sorry I can't see it etc... Good luck!
TT-TECH Veteran
Yeah I can't tell you what it is for sure. get a flashlight and look around is all I can tell you. did you reuse your water pump gaskets? I just replace them now I have had to many start leaking afterwards. If so they could be leaking and running towards the back of the motor etc. Good luck!
Jeff
Jeff
