LS6 Manifold & !AIR/EGR ?'s
Ok, I'm doing an LS6 IM swap and of course it seems like I can never fix something w/o breaking something else. So I snapped the plastic tube connected to the pass. side of the manifold. This the PCV tube or what? Goes from TB to the back of both valve covers I believe...
Then while I was yanking the AIR & EGR out of the car, I noticed there was a small tube leading off of the thin one that connects to the back of the manifold. I'm guessing it went to my AIR? Can I just block this off? Do I need a new hose? Or what?
Any tips/advice would be greatly appreciated!! TIA!!!
-Steve
-Steve
random, do you know where the short little tube goes to that goes to that one on the back of the manifold?... this is confusing. lol. i'll see if i can get a pic.
Here's a couple of really bad pics. The Yellow goes off from the rear of the manifold to where I'm guessing the HVAC. The Red part goes to the back of the manifold. The Blue part I'm confused about. Anyone else have this? I don't recall this when I did the LS6 swap on my old 99 Z28. Is this a weird 2000 thing? Thanks to you all again.
-Steve
-Steve
Also, does anyone know where I can pick up a cheap PCV tube? I called the dealership and they said it comes with the PCV valves and everything and runs somewhere around $100??!!?? ouch...
nikon1999- can you give me details on how you rigged that up? I may just have to resolve to that! best of all, it doesn't sound like anything close to $100
i'd say disconnect the big hose from the back of the manifold rather than disconecting it from the brake booster. Or disconnect it from the brake booseter, then disconnect it from the manifold. I believe that's what did it... twice...
