Jounce Bumper..w/ Prostars?
I did a search didnt come up with anything.....
do I need to remove the Jounce Bumper with Prostars?
15x10s
26x10 ET DRag...and I will run a 28x9 also
I have grinded the calipers and they are ready ...it looks like they need to be off...I cant remember if I took them off of my 95 TA or not....
Thanks
15x10s
Thanks
when you take off the wheel in the rear, you'll see this "thing" bolted onto the lower portion of the inner fenderwell in the middle. pretty much centered right above the axle. to prevent the axle from bottoming out. there is two bolts if i'm not mistaken that hold it on. you can just undo those and take it off. if you need to really fit a big tire in there, then that's when you need to start cutting and hammering.
I did not remove mine with my prostars (10" with 7.5"backspacing) I just grinded the rough edges smooth...I looked under the car with the wheels/tires (Nittos') on and it sits almost an inch away from the bumpstop.
