Hgh and low impedence Injectors.
Old 01-12-2005, 10:45 AM
goober35's Avatar
Default Hgh and low impedence Injectors???
I am starting to fuger out the fuel system. I still dont know witch ones to go with but i have to figure this out first and i think i have it right just need to make sure
Low impedence is for High fuel presure. But how high is high? Like 60-85psi
High impedence is for low fule prsure. But how low is low? like 40-60psi.
I want to do a twin Walbro 255 intake pump and a 1:1 fuel presure regulator. So as the Boost climbs so does the fuel presure.
Do i have this right or do i have it back *** words.
Old 01-12-2005, 11:55 AM
cablebandit's Avatar
good on fuel pumps/regulator...get the mototron 60# high impedance injectors and be done unless you are going over 800 rwhp. I know they will fuel to 800 but I dunno how much higher they go. Mightymouse had over 800 with his
Old 01-12-2005, 12:18 PM
MIGHTYMOUSE's Avatar
they both work in basically the same pressure range far as i know
high impedance is what your stock computer can run. that is what you need.
low impedance is when you can't get enough fuel with high impedance.. you need an injector driver box or an aftermarket ecm to run them.
Old 01-12-2005, 04:10 PM
goober35's Avatar
Ok thanks guys.
I know the 60# will handle it but will they handle for a DD.
Old 01-12-2005, 04:34 PM
my car is a dd and mototrons are an 0EM grade injector
Old 01-12-2005, 04:56 PM
goober35's Avatar
Thanks dave. I also need to know how to set up a dual walbro 255's. I check your web sight for any pics.
Old 01-12-2005, 05:47 PM
you need to get with smokinhawk he has the same tank as you.
Old 01-12-2005, 05:54 PM
goober35's Avatar
Ok man thanks. Hey motor goes in monday or tueday depending on when my k member.
Old 01-13-2005, 09:01 PM
Mike @ New Era's Avatar
Mightymouse is right , you need high impedence to utilize the stock drivers in the computer , it has nothing to do with fuel pressure . As for the Motorton #60's , we have them in stock and on sale for the lowest price we have ever had them at at $439.95 shipped if you need a set . Feel free to call or email me if you would like to discuss your options further .
Mike
www.neweraperformanceparts.com
sales@neweraperformanceparts.com
585-865-1832
