How much HP can 26lbs injectors handle?
I've got a 99 so I've got the smallest injectors. 26.xx
So whats the limit on HP before they're maxed?
Gettin ready to spray so i'm trying to get my ducks lined up. Already have a Racetronix fuel pump. Going to spray 125 on a TNT kit. Currently puting down 378 to the wheels NA.
with my 28lb injectors and a 150 shot my injectors were running about 70-75% duty cycle if i remember correctly so I think you should be fine...i'd look into a new fuel filter as well
Originally Posted by CarsRFun
415 eh???? how can you tell the duty cycle?
There is a chart somewhere in here that should give you your answer. I don't know exactly where it is but you should be able to locate on a "search".
I'm going to be around 400-425 RWHP and I'm going to the 28.8's (own a '00).....which should keep me down somewhere around 70-85% on the duty cycle.
