Dynamometer Results & Comparisons - F13/header numbers inside!
Bluehawk27
01-12-2005, 09:44 PM
Numbers are with the cam on a 112+4, pacesetter headers and a TSP catted Y pipe with a cut out, a march pulley, and Stock TB, and my Stock injectors are completely maxed out at 100% so he said thats all he could do with it for now.
Uncorrected :408rwhp & 397 RWTQ
Corrected: 390 RWHP & 379.8 RWTQ
I am pulling about 310RWTQ and up from 2000RPM all the way to 6800RPM
Let me try to post the dyno graphs.
Mizfit MotorSports
01-12-2005, 10:04 PM
Is this tuned? Numbers look good.
even with the 4* advance it appears to peak way early to me.
BLASTER
01-12-2005, 10:16 PM
Maxed out? What was your air/fuel? Looks good, none the less. I think with a TB and !CATs you would be right at 400. Actually I am hoping for very similar results. I want to hit 400+ with my F13 and tuning. Anything over 400 and I will be :headbang: happy as shit.
BLASTER
01-12-2005, 10:17 PM
Good catch. Yeah, that is weird.
AINT SKEERED
01-12-2005, 10:28 PM
Mine did not max out untill around 6400-6500. carried well over 6800. I dont have a scanner to post a graph but I can see if Candy can email it to me. Mine is an awsome power curve on hp and tq.
I do have a little better then stock heads which may move the peak up a little.
Bluehawk27
01-12-2005, 10:36 PM
Well this is tuned and I lined it up dot to dot dont know what else to tell ya
Ben R
01-12-2005, 10:58 PM
Dot-to-Dot isn't exactly full-proof.
Bluehawk27
01-12-2005, 11:05 PM
That may be so, but i cranked it over a few times and it was dead on everytime it came around.
Candy
01-12-2005, 11:11 PM
Good to see you got the cam in, nice number. Did they say why they thought you were max'n out your stock injectors? Just curious because we have started hearing this alot lately and we have never ran into this issue at 400 rwhp.
LSUxBlake
01-13-2005, 12:50 AM
I was wondering that too. I thought the 28.8's were good to around 450rwhp.
Bluehawk27
01-13-2005, 01:15 AM
He didnt offer an explanation as to why they maxed out, all he said was that they were so i'm gonna have to buy some new injectors. Thanks for the cam by the way.
John02SS
01-13-2005, 01:31 AM
Dynoed mine on Tuesday. With AS 5.3 heads it did 435/409 SAE corrected in some crappy Florida Humidity (98%). I was looking for a few more, but weather conditions soaked those up I believe. Very happy with the cam and the power/driveablity it offers. Mine is a 112+4 also and peaked about 6350 and the injectors are fine on mine. The duty cycle is getting kinda high, but it held 12.9 A/F till 6800 with no signs of fuel issues. Good numbers man!
LS1_PNYTAMR
01-13-2005, 01:32 AM
hmm this is intresting... good numbers regardless.
Black02SS
01-13-2005, 01:42 AM
Looks fimiliar....
Bluehawk27
01-13-2005, 02:23 AM
how does it look familiar?
LS1_PNYTAMR
01-13-2005, 02:30 AM
well i heard futral cams +4 usually peak around 6200 and have great under the curve power, that one looks like its sub 6000 peak though.
Bluehawk27
01-13-2005, 02:41 AM
Well if it makes any difference, he didnt want to go too crazy with timing because of the duty cycle on my injectors and my car seems to like a leaner a/f mixture.
Nickn20
01-13-2005, 03:47 AM
Injector Duty cycle was at 111% on the last pull AFR was about 12.9:1 leaner than I like to put cars at, typically i like 12.5-7 or so. his timing advance was 26-27 degrees, one he has cats, and two its a tad lean. I tend to lose control of an injector around 100% and industry standard is have them at 80% DC or less.
Bluehawk27
01-13-2005, 05:28 AM
Thanks Nick! It was great working with you. :)
smacz28
01-13-2005, 02:43 PM
Those numbers suck........J/K What should that run in the 1/4 if this guy can drive??? I need a cam in my Hawk or Z06 now :(
Kalijah98z
01-14-2005, 03:39 PM
Allan made more power than that with my motor and he said nothing about the injectors being maxed out. That does sound wierd?
AINT SKEERED
01-15-2005, 08:33 PM
Mine made 420hp and 405 tq through the 12 bolt and 4.30 gears . stock 26 lb injectors and tuned to 13.5/1 a/f on allens Dyno . No signs of a fuel problem either and we pulled it to 6800 every pull. peaked around 6400 rpms
Bluehawk27
01-16-2005, 05:41 AM
Thats weird,
While you do have heads and a ported TB, you have smaller injectors than mine. I wonder if a few of us could have gotten smaller or a bad batch of injectors in our cars. I also think my clutch is about to give out. Your 12bolt and 4.30 gears arent helping ya out either. I'm gonna go ahead and Port my TB and get some larger injectors and see if that doesnt do the trick.
John02SS
01-16-2005, 09:25 AM
Do you mean 12.5 or did you guys dail it in lean. Mine make more power that lean, but I was scared to set it there for the street. Thanks bud!
Black02SS
01-17-2005, 07:55 AM
My car does the same thing.
http://home.insightbb.com/~herrieschopper/224fm11.jpg
The blue graph is with my FM11(114+4) and TEA Heads, the red is 224(112+0) and TEA Heads.
BLASTER
01-18-2005, 12:04 AM
So you lost power going to a FM11 over a 224?
LS1_PNYTAMR
01-18-2005, 12:43 AM
damn sure hope not?!
:nod:
how the hell is that?
Black02SS
01-18-2005, 04:29 AM
We don't know. The only change in my car was the cam swap, LS6 to 78mm LSX intake(Made 5hp on another car), Mac headers to Flowtechs and a Hooker Catback from True Duals. We thought it was the springs so I swaped them out and that didn't help either.
I have since put my setup close to where it was before. I removed the LSX intake, put a set of Pacesetters on and back the True Duals. I am hoping to get the car dyno'd in the next few weeks. But yea, even with that setup, I lost power over my 224 and it didn't make NEAR as much as I had expected with the TEA heads.
AINT SKEERED
01-18-2005, 07:55 AM
Thats odd , although the 224 is a great little cam.
Black02SS
01-18-2005, 08:10 AM
Yea, its very odd and noone seems to know why. Or the fact it didn't make any power past 6100.
ulySSes
01-18-2005, 07:07 PM
ttt...
SLowETz
01-18-2005, 07:51 PM
Odd. Seems like there has to be something else going on. Was this a monitered tune(IE: AutoTap/ TechII etc.?) Is it possible that you've got some weird condition that isn't allowing proper injector pulse widths/rates? Sh!tty gas lately? Just seems like 111% DC, 12:9:1 A/F, & 27-9* w/that setup means something(relatively simple)is holding it back. What's the FP look like @ WOT?
While(I realize)I'm running heads, I pulled 436/416 w/a smaller cam(F11), 29*, and 12:5:1 A/F(through a 12 bolt/4.56's/slicks), with no DC issues.
No pro here... just some thoughts....
Keep us posted.... Good luck!
Nickn20
01-18-2005, 07:53 PM
what did you log your duty cycles with?
Nickn20
01-18-2005, 08:13 PM
I will do some math for the people that think this is impossible.....
when comparing duty cycle to hp and AFR you need to use uncorrected numbers his were 409 rwhp(colder weather means more hp which means more fuel!) I beleive, which equates to 409/.85 to get the 15% horsepower loss and fwhp is ~481 now, most LS1s drop to about 55 psi fuel pressure at WOT due to thier intank regulators, which lowers the injectors from 28.8 to 28.0x big deal.
So at the BSFC of .5 where a NA engine typically runs, the horsepower at 111% duty cycle is calculated hp is 498, so we are off by about 17 hp, so we are pretty close to what is actual, that could easily be covered by being off a psi in fuel pressure, or a few hundreds in BSFC or a few % in drivetrain loss....... hope this helps some people, out.
I will also state yes these injectors can do a lot as far as HP wise, but they are completely out of control in the 400-420+ rwhp range.
Black02SS
01-18-2005, 09:22 PM
Not to hi-jack his thread, but what is the ICL and LSA of your cam? My FM11 didn't make good numbers at all.
