o2 sensor code please help
I just got a tune from tsp and got my computer in let it run for a while. the idle is surging and texas-speed said to adjust the idle screw to fix as I did and it did not fix the prob could this be related to the code it is trowing? it said p0134 bank 1 sensor 1 no activity. anyone know which sensor this is pass or driver. I don't have cats and had those deleted from computer. what does no activity mean?
any help would be great thanks
That is the drivers side sensor, and yes that will definitely make it run crappy. Swap your O2 Sensors around (put the passengers on the drivers side, and drivers on the passenger side). If it changes to b2s1, then the sensor has crapped out. If it still stays that it is B1S1, then there is most likely a wiring problem to that sensor.
