Header wrap is bad
Old 01-14-2005, 03:14 AM
Richiec77's Avatar
Default Header wrap is bad
Here is a link I found that makes a pretty good point as to why you should coat a header and not use header wrap.
http://www.centuryperformance.com/heatwraps.asp
Make a compeling point.
Old 01-14-2005, 04:19 AM
Deranged Rat Fink
badjuju342's Avatar
Excellent points ! The coating does two things INSIDE the header: 1.Provides a smooth surface for better flow. 2. Prevents the header from coroding from the inside out.
Old 01-14-2005, 07:19 PM
CamaroSS01SLP's Avatar
So according to the article, a coated, mild steel header is better than an all stainless steel, uncoated one huh?......Wow, interesting.......I'm happy with my FLP's.....
