"862" cast in head..is this 5.3 or 4.8??
Old 01-14-2005, 03:43 PM
blwn327's Avatar
Default "862" cast in head..is this 5.3 or 4.8??
can you tell me if this casting is a 5.3 or 4.8??? thanks!
Old 01-14-2005, 03:49 PM
NO-OPTION-2002's Avatar
Hello,
This was supplied on either 4.8L or 5.3L and will work on either.
Hope this helps!
Old 01-14-2005, 04:01 PM
blwn327's Avatar
so they are the same exact head?? just want to make sure ..it is for a friend and I have these that came is a core at work...he wants the 5.3 heads. Thanks!
Old 01-14-2005, 04:31 PM
ktmrider's Avatar
Both are exactly the same, no differences at all. My 99 4.8L had them as do all the other 4.8/5.3 motors I have looked at.
Might save you some money if someone thinks the 4.8L heads are not worth anything...
Old 01-14-2005, 08:25 PM
mrr23's Avatar
862 are 4.8L heads. i just put them on my wife's 99 formy. https://ls1tech.com/forums/generation-iii-internal-engine/209140-vhp-heads.html
Old 01-15-2005, 10:38 AM
ktmrider's Avatar
Originally Posted by mrr23
862 are 4.8L heads. i just put them on my wife's 99 formy. https://ls1tech.com/forums/showthread.php?t=209140
Not specific to the 4.8L. BOTH the 5.3 and 4.8 have the 862 castings. Check out the sticky note above for "Head Volume..." for more info.
Old 01-15-2005, 12:06 PM
mrr23's Avatar
well he asked if the 862 was for a 4.8L or 5.3L. on the 862 heads i have, you flip them over and you'll see 4.8L cast into the head under an intake runner. but yes, it's for both motors.
taken from here: http://www.pera.org/CoreTalk/eb120317.htm
The cylinder head for both engines is aluminum with a casting number of 862, however on the deck face area in a small cavity there is a 4.8 cast onto the cylinder head. Do not be confused by this cast number for the cylinder head is for both 4.8L and 5.3L engines.
Old 11-03-2007, 09:26 AM
crazyhorse's Avatar
anybody know if 4.8 heads can be upgraded for better performance and flow or are they not worth the time or money?
Old 11-03-2007, 11:26 AM
RIDINFILTHY's Avatar
i would say they are the same head
Old 11-03-2007, 04:07 PM
mrr23's Avatar
man this is an old thread.
anyways, my 862 heads were ported through www.vincihighperformance.com and 2.02/1.60 ferrea valves were put in.
here's the flow sheet.
Old 11-03-2007, 04:31 PM
ktmrider's Avatar
Most/all the performance shops start with the 862 castings and port/CNC from there. They have more "meat" in the combustion chamber ( different CC for smaller 4.8/5.3 bore ), always easier to remove material than add.
Long story short, the 862 casting is great once you work them over a bit.
Quick Reply: "862" cast in head..is this 5.3 or 4.8??
