Are my fans even turning on????
Doesn't seem like they are... I've never heard them once since owning the car. When driving normal the temp is fine, at a stoplight or in a drive-thru my car heats up VERY quickly (~224*). How can I tell if my fans are turning on? Should I replace the T-stat? Any other suggestions? Please help!!
the way that your radiator is set in, on an angle, with no direct air-flow hitting it, expessally when stopped, these cars heat up, either turn the fans on earlyer, or dont stop for very long, 224 isnt bad, just make sure it doesnt go up much higher than that, to make sure your fans are on, unless your exhaust is really loud, turn the radio off and listen, if your stopped, pop the hood and take a look
Originally Posted by BlackTA98 LS1
I also see you have a 98 f body. We have the actual working gauges so dont' be alarmed when it goes up and down.
Originally Posted by LiquidFire350
wait, are you saying i have a 98, my gauges work all the time, go up, go down, i see them moving all the damn time
