Throttle Body
Throttle Body
What is the largest throttle body that will fit on an LS6 intake? Is there a 90mm made to fit???? Or would that be pointless because of bottleneck in intake opening? Need to upgrade the stock TB for my new 408 and dont want to spend all the money on an LSX...
Hmm.....I'd pick up a FAST intake/tb setup and call it a day. Otherwise, you could blow a TON of cash also on TPIS' modified LS6 intake and oval TB, but thats about the same as the FAST setup when you're done. Either way, you won't get nearly as much out of your motor with the LS6/ported tb route.
