Engine Missing
Old 01-16-2005, 03:34 PM
Ed Blown Vert's Avatar
Default Engine Missing
Engine is starting to miss when I first start it in the morning. Once it warms up, it goes away. EFI says I am missing on #7. I pulled the plug. Has some green on it, coolant? I think I may have a leaky head gasket. Or could it be something else??
Old 01-16-2005, 04:01 PM
goober35's Avatar
well it is not coolant sence GM used the pink stuff.
Old 01-16-2005, 04:09 PM
Duh, I knew that. :sillyme:
Old 01-16-2005, 04:44 PM
Cal
Cal's Avatar
Swap a different injector onto that cylinder, then see if the miss follows the injector. Try the same thing with the coil pack for that cylinder. If neither of those tests issolate the problem, do a compression test on that cylinder and a couple others to see it it's in line.
In any engine you need three basic things: fuel, spark, and compression.
Old 01-16-2005, 04:56 PM
MelloYellow's Avatar
Wire on #7?
Pull #8 also, OBD can give you bad data coming from the opposite cylinder.
Old 01-17-2005, 02:56 PM
Thanks for the suggestions, I went ahead and installed another plug since I had the old one out. Seems to fix the problem. :dunno:
Old 01-17-2005, 05:47 PM
Muffracing's Avatar
How many miles on plugs? May just need a tune up.
Old 01-17-2005, 07:07 PM
Most likely. Was planning on changing them when I do my head swap.
Old 01-17-2005, 07:10 PM
Squintz Palladoris's Avatar
Did you find the Missing Engine?
Old 01-17-2005, 09:20 PM
Ragtop 99's Avatar
Keep an eye on #7. That seems to be the first cylinder to pop on an FI car when you blow a head gasket or piston. I think it must be in the manifold.
Old 01-17-2005, 09:23 PM
Thanks, I actually think I have already blown the head gasket.
Old 01-18-2005, 08:35 AM
BrentB@TEA's Avatar
I would do a leak down on that cylinder. You may have hurt the piston. I am not sure about your area, but this time of year plugs get weird colored up in the northern states due to fuel additives.
Old 01-18-2005, 10:39 AM
Cal
Cal's Avatar
You beat me to that comment!
