New cam only personal best
The weather was awesome here in NE Texas today, I had to get out and take advantage of it I weighed in at 3390lbs today, not sure how accurate the scales are. I think I'm closer to 3375. At the time of my new best the DA was -1080ft
1.46
6.790
99.44
10.738
125.06
My worste pass of the day was a 10.78. I ran sevaral 10.74's.
I also got a new best 60ft of 1.44, that run was 10.742
1.46
6.790
99.44
10.738
125.06
Originally Posted by DMcRacer
Thanks. A little more wt reduction and some 4:10's
if i can ever get off my *** and find the time to get to the track i got a lil somthing for ya.
great job donald, im sure your pumped, now we both have to go faster than a 10.64 im sure it wont be a problem
btw, consider youself updated
Originally Posted by SMOKIN01TA
you finally ready for a rematch.
I did correct a minor issue that was costing me a little power. .
now get you a intake for that thing, i just had some extensive portwork done to my new 90mm fast combo im hopin that will be worth another hp or 2 and ive removed another 30lbs in crap and will loose 37lbs with the kmemb/a-arm combo+ few other things.
now i just need to catch some of that weather you had
me too, weight
Originally Posted by Coach 02 A3 Z/28
Congrats on the 10.73 run. Your hot rod is running real strong. When does your bracket season begain?
Coach
Coach
Very impressive donald You need to come over to RRR and race with us sometime. I may come back to hallsville soon but RRR is hooking to good to drive another hour to hallsville. I need to get all my stuff done and catch some -1000 DA to see if i can slap some 10.90s on the board.
Thanks. I dont want to drive another hour to RRR when Hallsville is hooking so good You better hurry, the good air wont be around much longer.
