Low voltage knock sensor code:24* of KR at 5800rpms. What is wrong?
Old 01-16-2005, 08:45 PM
StreetStalkerZ's Avatar
Default Low voltage knock sensor code:24* of KR at 5800rpms. What is wrong?
Could the knock sensor have gone bad? I check the knock sensor wires to the PCM and they look good so i was thinking the sensor could be the only other culprit to throwing the code??
While auto taping the car i would see zero KR until 4000 rpms and at that point i would get 4* then at 5000 rpms i get 19* and at 5800 rpms i get 24* and stay at 24* until the car shifts into 3rd gear.
Old 01-16-2005, 09:09 PM
horist's Avatar
what's the exact P code?
If the PCM detects any issues w/the Knock sensors it'll automatically started using the low octane tables... and I believe in most situations it'll set a constant 4* of knock retard
If you clear the SES does it work properly? Or does it come back right away?
If it keeps coming back then we have a bad sensor or wiring issue... I'll try to find the Knock Sensor test procedure in a bit (there's a post in here that describes how to test the sensors to see if they're registering right)
If it's setting low voltage for both sensors then it's prolly wiring... if only 1 could be wiring or could be the infamous knock sensor water leak issue on pre LS6 intake cars... (assuming the front sensor is the one setting the code)
Old 01-16-2005, 09:11 PM
horist's Avatar
https://ls1tech.com/forums/showthrea...Test+Procedure
that may help in diagnosing the knock sensor
Old 01-16-2005, 11:14 PM
We were wondering if it was just setting a code from one sensor or both but we could not tell?
Old 01-16-2005, 11:22 PM
horist's Avatar
what was the code ? P0xxx (P1xxx works too... P1 codes are manufacturer specific ... but most of the GM P1 codes are known)
If it's setting low voltage for the KR sensor ... it must be a specific code... what was/is the code ...
Old 01-17-2005, 10:29 AM
MCBRIZ28's Avatar
Scott if you need access to a scanner David has my stuff can have wife get it to you. It will do a good bit more than the auto tap.
Old 01-17-2005, 02:32 PM
Well i cleared the PCM this morning and drove the car around and the problem is gone with no SES light but i usually get a SES light after some driving anyway because of the converter. I figure if it's a wiring or knock sensor problem it should have came on after a few miles of driving. I will A tap again tomorrow night to see if im still getting some KR and will put more miles on it before i call it fixed.
Greg,im in the new house and settled in If i can get the car acting right it should be ready for some 11.0-10.90 passes in a few weeks,IF i can get some good weather. PM me and i'll let you know what is up.
Old 02-19-2005, 03:35 AM
ATTI2D's Avatar
I am having the same problem after a cam install. Pulls 4 degrees at WOT. Got a low voltage on back sensor...its been a while so I dont remember the exact code... I replaced the sensor and reset the computer...everything seemed good. Took the car for a spin and mashed it once...felt alot stronger...mashed it a second time and got a ses...Could a crimped wire...from the intake smashing it...cause a low voltage signal
Old 02-19-2005, 08:08 AM
Mine turned out to be a pinched wire on the PCM under the gray cover. I replaced the knock sensors and wireing harness under the intake and it worked for the first few WOT runs and then started all over again so i went back and replaced my old knock sensor wire under the gray cover on the PCM and the problem went away and has not been back since. I had this problem 2 years ago and spliced the wire and put a new wire in place of the pinched part but i guess the wire got old and was losing resistance and needed to be changed again.
Scott
Old 02-19-2005, 09:38 AM
1BADAIR's Avatar
Do any of you know the part number for the knock sensor harness, or have a good one laying around?? Mine did not look to good when I pulled the engine.
Old 02-19-2005, 04:28 PM
ATTI2D's Avatar
You can pick one up at a dealership...I paid like 27.00 for the one I ordered this morning
