costs of a Dyno tune, but own HPtuners
You have a couple of choices. Since all the dyno's around here seem to be way overpriced, i just tune using a g-tech. I dont think its accurate in terms of actual HP numbers, however, it is accurate against itself... meaning if you go out and pull 324 HP, then you change your tune and you pull 340 HP on the g-tech, its a safe bet that the new tune worked out for you...
A better way to do it is to go rent a dyno for an hour or two, with wideband support.
with what you're going to pay for a dyno tune you could buy the software and be able to make changes whenever you need to. Also, I've read of some dyno tunes doing quite a bit for the WOT but never touching anything for normal cruising which is what you are doing 98% of the time.
