Question about Z06 shift knob
Question about Z06 shift ****
Just a quicky....
Would the new Z06 shift **** fit on the Hurst Shifter that came with the SS? I need something besides the H cause that is gettin worn on top and I like that look of the shifter with the metal plate up top. I know that Cobras fit with a little work but I aint crazy about having a gray lether with the black interior.
If it doesn't fit anyone know where you can buy a shifter like it?
Thanks.
Thanks.
Well doesn't that just blow? Any idea of where I can pick up a shifter similar? I really like the brushed aluminum look with the gears on top.
if you drive your car in the winter....you might not want a brushed aluminum shifter.....makes your hands damn cold having to hold that thing while driving........just something to ponder.......i do know that SLP has some shifter *****.....i do know they have the stock hurst one....but I don't know if they have any others
i like the cobra ****. its only 40 bucks too. only problem is you need to rethread the ****, or the stick. but i found someone on here that is making me a new short stick with stang threads cheaper than a reg short stick too
