Pcm is locked....what now?
Old 01-17-2005, 08:21 PM
mjf454's Avatar
Default Pcm is locked....what now?
I just got my HP tuners today, so I go out to read the pcm and Mike Morgan has locked it, WTF. How do I go about unlocking this? I figure all the money I have spent on tuning, whatever is in there is mine. Can you help me?
Thanks,
Mike.
Old 01-17-2005, 08:36 PM
narcszm's Avatar
Well they don't want you copying "their" tune to others' PCM. If you send it back to them, or any other tuner with Tuners PRO, they should be able to unlock it.
Old 01-17-2005, 08:38 PM
horist's Avatar
how do you know it's locked? What error are you getting?
Old 01-17-2005, 08:46 PM
mjf454's Avatar
I am getting...security access denied. And MMS is out of business.
Old 01-17-2005, 09:01 PM
horist's Avatar
hmmm... email support@hptuners.com ... send them all you can , and also do the VCM Info thing in the read/write tool (help -> vcm info)
send them all this info if it appears
Old 01-17-2005, 09:44 PM
mjf454's Avatar
Thank you.
Mike.
Old 01-17-2005, 10:19 PM
mjf454's Avatar
Will Hp tuner pro be able to unlock the pcm or will I lose my tune and have to go to a stock tune and start from scratch?
Old 01-17-2005, 10:20 PM
horist's Avatar
not sure exactly, i've never had any dealings w/locked PCMs... and it really depends on how he locked it ... HPT support should be able to let you know the options though
Old 01-18-2005, 09:19 AM
gomer's Avatar
I had the same thing happen to a car I was working on. The guy who locked it refused to unlock the PCM. My customer had to buy a spare PCM and then have it flashed with a stock program, then I made the tuning changes. The place that locked it and wouldn't unlock it was called "Street and Performance". The do alot of LS1 conversions, don't ever buy a PCM from them, they will send you a locked one.
Old 01-18-2005, 09:24 AM
LS1TECH Sponsor
foff667's Avatar
Appearantly most tuners dont keep the stock file for their customers...when i had cartek unlock mine they ended up using a tech II to flash it back to stock...later i found it ls1edit locks it differently and i couldve changed parameters without issue via hptuners.
Old 01-18-2005, 12:01 PM
slow's Avatar
Tuning it back to stock with a tech 2 has advantages, such as being the latest revision for that vin number. where if you started with an older version, you can benefit from a new "stock" file.
I updated mine with a tech 2 before i started tuning my vehicle, since i had used a hypertech on it at one point.
Ryan
Old 01-18-2005, 07:52 PM
00blkws6's Avatar
We had the exact same problem at our shop once. Street and Performance tried to tell us they didn't lock the PCM.
Old 01-19-2005, 06:05 PM
mjf454's Avatar
Well I spoke to Rob at Strictly performance today. He says they are close to unlocking Mikes pcms. That will be great because there are a lot of cars that have his tuning in them around here.
Old 02-10-2005, 02:18 PM
LT99LS1's Avatar
Narcszm, I sent you a pm.
