thermal wraping on stainless
Old 01-17-2005, 09:07 PM
obZidian's Avatar
Default thermal wraping on stainless
hey, installing the dyantechs in about two-three days and a buddy ws telling me why dont i wrap my headers. I know that stainless resist corrosion but could possibly generate more heat.
Wat do ya'll think?
if so, wat kind of wrap should i use. I want to make as clean looking as possible. My block is black, is there black thermal wrap?
Old 01-17-2005, 09:48 PM
LS1LT1's Avatar
I wouldn't wrap them.
Old 01-17-2005, 10:26 PM
2001CamaroGuy's Avatar
do not wrap....coat.......wrap holds heat into the metal and will fatigue it........coating keeps the heat from even entering the metal (keeps in the exhaust gas) so everything lasts longer and you will get more performance out of it........wrap = OLD/LOW tech.....
Old 01-18-2005, 12:27 AM
obZidian's Avatar
ok, thanks, but do stainless create alot of heat or more than steel when coated?
Old 01-18-2005, 12:29 AM
coated steel will run cooler than stainless.......but coated stainless is the best you can do....
Old 01-18-2005, 01:18 AM
LS1LT1's Avatar
Stainless creates/generates less heat than mild steel, uncoated.
Same if both were to be coated.
