slp 85mm maf
slp 85mm maf
has anyone used the 85 mm MAF sensor from slp. is it worth the money. and why is it only 165 dollars, and the other ones out there are around 300-400 dollares, and are only 75, or 80mm. my 2000 TA already has an ls1 motorsports lid, ported tb, and ported maf ends, as well as a thunder racing cam, and slp LT's. should i spend the money, and get the slp MAF sensor.
I had a home ported stock MAF, didn't cost a thing. I bought a SLP 85MM,,,, didn't pick up squat,,, nada,,, zip,,, ziltch. I can swap them at the track and see no difference in mph. Would not buy another.
!LS1 11 Second Club
I got it on my 00 ws6 slp 85 mm bbk 80 mm tb retuned it with the predator car runs great picked up .4 tenths in the 1/4 worked pretty well for me dispite all the bad talk about aftermarket mass air meters
!LS1 11 Second Club
Aftermarket MAFs just lean you out a bit. On a stock car, the leaning helps you pick up some power. It's a simple trick.
