changing a 98 car to a 99 pcm what is needed
Old 01-18-2005, 08:00 AM
smokinHawk's Avatar
Default changing a 98 car to a 99 pcm what is needed
what all is needed to switch a 98 car to a 99 pcm?
i have heard the newer pcm will need the 99 harness, but will the 99 harness end connect to the sensors and such to the 98 car, or is it more involved then that?
what model years share the same harness?
Old 01-18-2005, 09:24 AM
slow's Avatar
https://ls1tech.com/forums/showthrea...highlight=1998
Ryan
Old 01-18-2005, 09:44 AM
88SS LS1's Avatar
The 99-02 can be switched out with no problems because they are the same pcm but with different programing. The 98 pcm is a different pcm completely, Your best bet is to get the 99 pcn with the harness because the 98 and 99-02 pcm are wired up diferently. Such as the 98 oil pressure sensor which uses 2 wires and the 99-02 uses 1 wire
Old 01-18-2005, 09:46 AM
slow's Avatar
also 98 water temp is 3 wire vs 2 wire on 99+
Ryan
