Drag Racing Tech
E.t. Estimates
Old 01-18-2005, 09:08 PM
Transam427's Avatar
Default E.t. Estimates
hey guys, I'm in the middle of a project, and need to know how fast my car is gonna be in order to build it up accordingly. It's a Big chevy with about 850 hp and tq. not sure about tranny, dana 60 rear with 4.10s and 325/50/15s in the back. This car will be the stock weight + the added weight of the big block/rear end/ tranny/ subframe connectors. Any help on estimated E.T. in 1/4 mile would be greatly appreciated. Thanks guys.
Old 01-19-2005, 08:05 PM
GueSS Who's Avatar
Well if that is 850 to the wheels I would imagine a 3800lb car with driver would go around 9.5s.
Old 01-19-2005, 11:16 PM
Nate_Taufer's Avatar
is this an f-body? if so i would imagine a lot more than 3800 lbs with driver. A fully built big block weighs a good 200+ lbs more than a ls1. then the rear will probably add 30 lbs, and the other necessities that make it reliable. But built right, it should still go 9's.
Nate
Old 01-20-2005, 10:16 PM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
850 hooked up right from the start and geared to use the power effectively should run anywhere from 9.40's to 9.90s depending on a bunch of factors (trans and convertor of choice, or manual and such to go with that, suspension, hook, etc etc)
Derek
