How much is too much spring load/lobe acceleration
Old 01-19-2005, 01:13 AM
GrannySShifting's Avatar
Default How much is too much spring load/lobe acceleration
on a stock lifter? What kind of closed and open pressures have guys run on stock lifters, steel valves
Old 01-19-2005, 08:36 PM
DAPSUPRSLO's Avatar
Good luck getting these kind of answers Jeff. I have asked this a few times. Put it in and try it.
Old 01-19-2005, 09:17 PM
i know what you can do with the Comp Rs, but I want to try something with the stock lifters. Everyone is skeered of them thoguh I take it
Old 01-20-2005, 06:06 PM
Nick, did you measure your installed height on your setup, and you used Pat spring seats, retainers, and which stock or the super7 lock? The variances you found were roughly about 6# difference in seat pressures.
