red calipers?
or buy a set of these...
http://community.webshots.com/photo/...62174353YUJtRM
or these...
http://community.webshots.com/photo/...65488827TJVSRw
or these...
What kinda paint did you use? I just bought a dupli-color kit from wal-mart but gotta wait till it gets a little warmer around here.
Did some reading in the handling/brake section and it seems the biggest factor is prep work.
Originally Posted by 777
clean them with brake cleaner then sand them down...use hi-temp paint...
I agree with 5.7, prep is the most crucial part take your time and do a good job. I suggest removing the calipers it makes the whole job alot easier. That's what I did and did it once, everything is holding up just fine.
when i painted mine i left the calipers on. I got a plastic bag and covered the rotors. i sparyed, very little for my first coat on the caliper. waited till it dried, then i sprayed a second coat and so on. took me about 3-4hrs to do it. It's still there. btw, i used caliper paint - good to 900 degree's i believe. Good luck
