MTI X1 cam
I have a X1 on 114 for sale in the For Sale Section. Less than 1000 miles. It was an awesome cam, and a total sleeper... but too small for my 388 all-bore.
https://ls1tech.com/forums/showthrea...=1#post2336028
I have the X1 on a 114 and although I don't drive mine that often, I would believe it would be fine for a daily driver. My idle is set at approx. 1100 and it occasionally has trouble on warm starts (coming up, dropping off, and then stalling altogether unless you give it just a little pedal). On cold starts, it will surge for 10-15 secs., then settle down and hold idle. One question...I see a lot of guys with idles at 850-900...does this make it a bit choppier? I'm doing dual StreetPro cutouts while the car is away for winter and would like to maybe drop the idle a bit, especially if it will intensify the lope. 1100 seems a bit conservative to me, and with the limited mileage, perfectly tame street manners are not a paramount concern.
227/230 .591/.571 on 114 lobe
230/227 .591/.571
not a traditional split (if that's what it's call) like you have listed in your original post.
MTI X1 on a 112 in a 6-speed/tuned by Jayson right here. I've had it in the car for about 10,000 miles now. Im running the Manley spring and retainers along with MTI pushrods daily. Acceptable in traffic, but mine bucks sometimes (i not sure why...spec III and 3.42 gears maybe why...dunno?) Made 396 with bolt-ons.
Adam
Adam
