2-3 shift hits rev limiter
Old 01-20-2005, 12:31 AM
Silver02's Avatar
Default 2-3 shift hits rev limiter
At WOT my car hits the rev limiter on the 2-3 shift. Lowered my shift point to 5,800 and raised rev limiter to 6,300. Still hits rev limiter. I read some posts about trans being fluid starved when accelerating at WOT. Some posts said problem was fixed by over-filling fluid about 1 - 1 1/2 quarts. What kind of problem could overfilling the fluid cause. Car shifts and drives fine otherwise.
Old 01-20-2005, 01:49 AM
Zach@Texas-Speed's Avatar
your clutches are giving out it sounds like....mine did that too with nitrous and then i put a 3500 stall and transgo shifkit and bumped up the line pressure and shifts like a champ now...at 6600 rpm
Its just to tie me over until i can rebuild this sucker
Old 01-21-2005, 11:56 AM
brandonppr's Avatar
I got the same problem.
I was told that a deeper pan might help.
mine was 1/2 quart low on fluid I am going to fill it up and try that first.
Old 01-21-2005, 01:42 PM
Slacker's Avatar
Try lower MPH for the shift, I know that on my 98 with edit moving the RPM doesn't help.. I have to use the MPH, Try to lower a couple until it stops.
Old 01-21-2005, 05:44 PM
Silver02's Avatar
I checked the fluid last night and it was 1/2 quart low. I put 1 1/2 quarts in so I'm 1 quart over. It shifts great now.
Old 01-21-2005, 07:24 PM
1QuickT-A's Avatar
Put some LUCAS stop-slip in it and you will be amazed.. Trust me, this **** works!
