Will this cam work without flycutting my pistons?
Old 01-20-2005, 06:42 PM
git_sum's Avatar
Default Will this cam work without flycutting my pistons?
Specs are as follows
grind ls1 3349/3349 hr114.0 serial # v 4039
gross lift .581 .581
dur @.006 306 306
@.050 254 254
valve timing open close
@ .050 int 13 btdc 61 abdc
exh 61 bbdc 13 atdc
114 lsa
lobe lift .342
Also is that way to big for a 3500rpm stall?
Lift isn't all that big but it has a huge duration, what do you guys think?
Old 01-20-2005, 06:45 PM
XtrmLS1spd's Avatar
Yes it will. You do not have to flycut as long as you are running the stock heads. If you are running aftermarket heads, you wouldn't want to go over .598 or so and that's pushing it.
Old 01-20-2005, 06:46 PM
git_sum's Avatar
Wonder where i've heard this..... hrm.............
Old 01-20-2005, 06:59 PM
git_sum's Avatar
Anybody know?
Old 01-20-2005, 07:00 PM
XtrmLS1spd's Avatar
Old 01-21-2005, 03:50 AM
Nate_Taufer's Avatar
with 254 degrees of duration at .050 i would say clay it out. worst case scenario you have to flycut. My best guess would be that it wouldn't fit.
Nate
