What Torque are you using to install your race wheels?
Motorboater
Originally Posted by JS
Use a tq wrench,it loads the wheel correctly...
60 pass/70 pass/80 pass DONE
me and everyone i race with has never used a tq wrench to put any wheels, drag or otherwise on our cars. i'd start using mine if i had a good reason, car to share some info??
Originally Posted by SilverGhost
guess i've never heard really what, if any, bad things can happen by not using a TQ wrench?
I've seen guys using spacers that overtorqued and cut the studs on sticky tracks after a few passes. It looks funny on the video but not much fun in the hot seat when you loose a rear while on the launch.
Is that 100lbs on just the firebird or both cars bickelfirebird?
Rick
Rick
11 & 7 Second Clubs
100 lbs on the Firebird's rear Weld wheels and the lugs have spacers. The amount of torque for any given car's lugs/wheels is determined much the same way the torque for, say, main cap studs would be determiend, e.g., by the material and diameter of the stud. Our Firebird has 5/8" studs which require 100-110 lbs torque versus the smaller 7/16" stock F-body studs, which require 75 to 85 lbs.
