Fueling & Injection - fuel pump cutouts!!!
shadyredeyes
01-21-2005, 01:58 PM
Just wondering if anyone had some advice on changing out a fuel pump in a '99 Camaro. I've been thinking about cutting a hole in under carriage to do this from the inside of the car. Curious if anyone has information about where to cut the hole and any other precautionary measures that I should take. Any input would be much appreciated.
libertine1015
01-21-2005, 02:41 PM
Search for fuel door or fuel hatch or pump install. There are some good write ups burried around here.
shadyredeyes
01-26-2005, 07:18 PM
I'll try that, thanks.
Inspector12
01-26-2005, 08:16 PM
It will take you an hour to do it from the bottom if you don't want to cut up your car.
yomama
01-26-2005, 08:33 PM
Its not like doing a 93 to 97 its pretty easy to do from the bottom
Ryan
shadyredeyes
01-30-2005, 02:01 PM
I havent actually put to much thought into doing it from the bottom. But if it is easier, I'll probably tackle it this way. Not to hot on the idea of cuttin up my car!
redsscamaroboy
02-01-2005, 06:38 PM
Man that car of yours is real sharp looking!!!!!!!
Looks great.
Dave
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
