I think I have a turned lifter
Old 01-21-2005, 06:05 PM
Dipstick's Avatar
Angry I think I have a turned lifter
Engine started ticking so I checked all the pushrods. No bent ones. I did a compression check and all were around 170 PSI COLD except for #4. It was 225 PSI. I checked valve lift and all were around .450 except #4 intake. It is only .360. Would the infamous twisted lifter cause this? Anything else I can check before pulling the head? Engine is completely stock and is in a sandrail.
Where us the best place to get a head gasket and new head bolts? Can the head gasket be re-used?
Old 01-21-2005, 10:29 PM
Cal
Cal's Avatar
An LS1 sandrail, cool! I love sandrails! I've been thinking about building an LS1 Sandrail also.
Could very well be a turned lifter, I had one. But I don't know how to tell without taking the heads off. The head gaskets are not reuseable. The best head gaskets are the 2002 version from the dealer.
Old 01-22-2005, 09:16 AM
Dipstick's Avatar
LS1s in sandrails are like VWs in sandrails were 6 years ago; everywhere. If I have to pull a head, it will only be the right side. I want the same gasket it has now.
Old 01-22-2005, 07:55 PM
Boosted One's Avatar
did you check for a bent pushrod?
Frank
Old 01-22-2005, 08:00 PM
2MuchRiceMakesMeSick's Avatar
I think he did Sounds to me like a lifter. Any idea on how much that thing weights?
Old 01-23-2005, 10:41 AM
Dipstick's Avatar
My first sentence. "Engine started ticking so I checked all the pushrods." Boosted One, that cold weather got your brain going a little slow?
I re-checked it again at the pushrod. The lifter is sticking up. If I tap it down, then turn it over by hand, with a dial indicator on the pushrod, it comes up the same as the others. ~.300". Me thinks using 15-40W oil may have caused the problem. I use this ~1600# sandrail in temps ranging from the high 50s to the 80s. I will change to 5-30W and add a bottle of CD2 "Lifter un-stick fluid".
Old 01-23-2005, 12:18 PM
I better quit getting on here after 16hrs at work. I must have read right over that.
You added that in later just to make me think I'm crazy didn't you. lol
Frank
Old 01-24-2005, 09:20 AM
Dipstick's Avatar
Yeah, I would do that if I thought of it.
